Print Problem Rhino 6
Hi everyone,
I have recently been having problems trying to print my layouts. Every time I try to print the layout Rhino crashes. I had reinstalled Rhino and Adobe PDF (which I use as my printer) and it worked for a short time, but now Rhino is crashing again when I try to print. I have tried other PDF printers as well, but currently none of them work, Rhino crashes every time. Does anyone have an idea what the problem could be?
Thanks in advance!
Best regards,
Julius
Hi Julius -
Ideally, you’d be using the Rhino PDF printer.
At any rate, crashes related to printing most likely boil down to issues with the GPU drivers. You might have updated Windows recently and that can have done something with those drivers.
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 6 SR34 2021-2-3 (Rhino 6, 6.34.21034.07001, Git hash:master @ 2fec8130f097ca52a8bc9f334c3ed4a5921c5e30)
License type: Educational, build 2021-02-03
License details: Cloud Zoo. In use by: Julius Haussmann ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: LEN
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-11-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro T1000 (NVidia) Memory: 4GB, Driver date: 11-20-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.66
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-20-2020
Driver Version: 27.21.14.5266
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
Thanks for the quick reply! That makes sense, I’ll try it again with Rhino PDF printer.
