Rhino wip is hanging in retrieving license from license manager , it is not starting , this morning it started ok on my other pc now on the laptop it is not starting , , rhino 8 does start normal, i did download the latest version and installed it, no succes, safe mode could start no problem with that
strangly when i go to my files and right klik open with rhino wip it works ok .. the version that is not working is started from my desktop
Same - except the start up bar message where it hangs varies. And starting from Explorer does not help. And it sometimes will start.
Same version as you.
Same here, won’t start from the desktop icon. I can start it by going to Explorer and Open With on an existing design. Also, going to Help → Check for Updates hangs on V8 and WIP. Going to Tools → Options → Updates and Statistics also causes it to hang.
It’s working again …
Oops, spoke too soon … worked for a bit … hanging again …
It must be something computer related issue as on my other work pc it just works from the desktop taskbar so what is the problem ? anyone ?
A mix maybe. It has worked upto the last release. There are serveral of us with this problem, so it has something to do with the update, and maybe our PC configurations. I run windows 11, and have an NVIDIA card rtx 4070, and I think, their studio drivers. 64GB of ram.
Seems to be working here this morning … fingers crossed …
pc working , laptop not working no progress
If anyone can point to a thread how to fix this, please do!
After a few days of Rhino v9 starting successfully after the last release, it would again not start today.
Sorry that this thread went unnoticed.
do any of you still run into these issues?
If so, any information you can give about the machines that work, and machines that don’t work would be appreciated. For example, _systemInfo of Rhino 8 on the machines that don’t work to see if we can find something they have in common.
we do this afternoon here the fatcory pc settings there r9 works from the taskbar
Rhino 9 SR0 2026-6-2 (Rhino WIP, 9.0.26153.12415, Git hash:master @ 6e68e5bb66050c38dc698d4e273cb8b18eff6123)
License type: Commercial, build 2026-06-02
License details: Cloud Zoo
Expires on: 2026-07-17
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 24GB)
.NET 10.0.8
Computer platform: DESKTOP
Standard graphics configuration using OpenGL
Primary display: AMD Radeon 780M Graphics (AMD) Memory: 8GB, Driver date: 5-29-2026 (M-D-Y). OpenGL(4.6.0 Compatibility Profile Context 26.6.1.260513)
Accelerated graphics device with 5 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 5-29-2026
Driver Version: 32.0.31019.2002
Z-Buffer depth: 24 bits
Total Video Memory: 20370 MB
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Cooperlake MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26153.12415
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\export_ACAD.rhp “AutoCAD file export : export_ACAD”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26153.12415
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26153.12415
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26153.12415
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26153.12415
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26153.12415
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedPositions.rhp “Named Position”
Both are running fine now after a few updates.
| Item | Value |
| OS Name | Microsoft Windows 11 Home |
| Version | 10.0.26200 Build 26200 |
| Other OS Description | Not Available |
| OS Manufacturer | Microsoft Corporation |
| System Name | LEGION |
| System Manufacturer | LENOVO |
| System Model | 82WR |
| System Type | x64‑based PC |
| System SKU | LENOVO_MT_82WR_BU_idea_FM_Legion Pro 7 16IRX8 |
| Processor | 13th Gen Intel® Core™ i9‑13900HX, 2200 MHz, 24 Cores, 32 Logical Processors |
| BIOS Version/Date | LENOVO KWCN54WW, 22/10/2025 |
| SMBIOS Version | 3.4 |
| Item | Value |
| Name | NVIDIA GeForce RTX 4070 Laptop GPU |
| PNP Device ID | PCI\VEN_10DE&DEV_2860&SUBSYS_3B5D17AA&REV_A1\4&23A2E0A&0&00E0 |
| Adapter Type | NVIDIA GeForce RTX 4070 Laptop GPU, NVIDIA compatible |
| Adapter Description | NVIDIA GeForce RTX 4070 Laptop GPU |
| Adapter RAM | (1,048,576) bytes |
| Installed Drivers | C:\WINDOWS\System32\DriverStore\FileRepository\nvltsi.inf_amd64_acf18fc3… |
| Driver Version | 32.0.15.9174 |
| INF File | oem273.inf (Section395 section) |
| Colour Planes | Not Available |
| Colour Table Entries | 4,294,967,296 |
| Resolution | 2560 × 1600 × 240 hertz |
| Bits/Pixel | 32 |
well works here also on the laptop that was previus not working so ok
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 16GB)
.NET 10.0.8
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 7-29-2025 (M-D-Y). OpenGL(4.6.0 - Build 32.0.101.6987)
Integrated graphics device with 4 adapter port(s)
Primary OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 7-29-2025 (M-D-Y). OpenGL Ver: 4.6.0 - Build 32.0.101.6987
Integrated (slow!) graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 32.0.101.6987
Driver Date: 7-29-2025
Driver Version: 32.0.101.6987
Total Video Memory: 2097148 KB
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 9.0.26153.12415
