Iam having issue with Rhino V7 & V8 starting. I can login to the license server via foxfire, but cant reach it via Chrome. Iam WFH. At work Rhino runs fine. Are the any network issue with the license server?
Getting this error on my seat of Rhino that works at work not the WFH system.
Rhino will run in safe mode.
Japhy
(Japhy)
October 3, 2023, 9:30pm
3
Hi Dave, can you open in SafeMode and run SystemInfo in the Rhino command line and post the result? Thanks
Safemode is sans plugins and video drivers…
brian
(Brian Gillespie)
October 3, 2023, 9:42pm
4
While reading your post, I’m not sure what the problem is.
It looks like at work you can:
Login using Chrome and Firefox
You see a plug-in load error for SelectionTools.
When you’re at home:
You can login using Firefox, but not Chrome
You can see https://api.mcneel.com from something, but your screenshot hides what browser is problematic.
So, since you can login using Firefox, why not set that as your default browser, and then Rhino will use it when you try to login from home?
Am I missing a different problem?
Hi Brian,
Main problem is Rhino will not run on my laptop. Worked last week.
Ive uninstalled it but there is still a Rhino WIP program in my Windows/apps and it wont install.
Are there any ports to check to see if they are close or Firewall issues?
Thanks,
Dave
theoutside
(Kyle Houchens)
October 3, 2023, 10:23pm
6
what happens when you launch rhino at home? Does rhino start but not license? or is it a plugin you are missing?
brian
(Brian Gillespie)
October 4, 2023, 9:31pm
7
Hi Dave,
The answers to your questions all are “it depends”. There are many of reasons why Rhino won’t install or run - can you please send screenshots of any errors you see? That will help us help you. Without the specific error messages, we’re just guessing - and we’ll all be extremely frustrated.
Hi Bill,
Ive left my Laptop at home, can send you some screen shots this afternoon. When launching Rhino it go through initializing to the point that stalled on the splash screen it stalls at loading plugins. It will run if I start it through safe mode. Another odd part was when I check the license server I cant log into the server via Chrome or foxfire but Edge will log in.
Iam adding Terry from IT to this tread. Maybe something beyond me that your two can figure out.
Thanks,
Dave
HI Kyle,
It will not start at home it closes at
But will start in Safe mode.
theoutside
(Kyle Houchens)
October 6, 2023, 5:19pm
11
Hey Dave, please go to help>check for updates and grab the latest beta-
then check your windows update to make sure it’s fully updated, and your graphics drivers as well to make sure they are updated fully.
any better?
Kyle,
Rhino was stalling at the cycles plugin so when it would start Rhino in safe mode I turned it off and it would start in regular mode. Is this an issue with the Cycles plugin?
Thanks,
Dave
theoutside
(Kyle Houchens)
October 6, 2023, 8:45pm
14
try going to programs and features> rhino>modify>repair
any luck?
HI Kyle and Terry,
The updated didn’t fix it. I noticed at the point that it was stalling on the startup screen it would stop at Loading the Cycles plugin. I started Rhino V8 in safe mode and disable it that got it to run.
Then this moring I went to run Rhino V7 and it noticed on the same start screen v7 stalled on loading the 3dConnecx Plugin.
What is that its stalling on loading some of these plug-ins?
Going to put Terry, our IT guy, on to chime in as well.
I have Rhino on other computers this is not a problem.
Thanks,
Dave
theoutside
(Kyle Houchens)
October 9, 2023, 3:44pm
16
Any chance you have any citrix programs installed? We have seen conflicts with them in the past.
if you can get rhin open, please run the systeminfo command and post the result.
Rhino 8 SR0 2023-9-28 (Rhino 8 BETA, 8.0.23271.13233, Git hash:master @ 4acd4a788d5f9e7999c3d49c07cdd2f60038b920)
License type: Commercial, build 2023-09-28
License details: Cloud Zoo
Expires on: 2023-11-12
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.11
Primary display and OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y). OpenGL Ver: 4.6.0 - Build 30.0.101.1404
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y). OpenGL Ver: 4.6.0 - Build 30.0.101.1404
> Integrated (slow!) graphics device with 3 adapter port(s)
Secondary graphics devices.
NVIDIA Quadro T2000 with Max-Q Design (NVidia) Memory: 0MB, Driver date: 6-2-2023 (M-D-Y).
> Integrated accelerated graphics device (shares primary device ports)
- This device is not being used
ATTENTION:
Laptop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
* Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 30.0.101.1404
Driver Date: 2-18-2022
Driver Version: 30.0.101.1404
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp "SimLab PDF Exporter"
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp "Commands" 8.0.23271.13233
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.0.23271.13233
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.0.23271.13233
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp "MeshCommands" 8.0.23271.13233
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 8.0.23271.13233
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.0.23271.13233
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp "SectionTools"
theoutside
(Kyle Houchens)
October 9, 2023, 6:15pm
18
I’d start here^^
it appears your nvidia is not being used.
see this thread-
Hybrid graphics laptops are more and more common if you buy a consumer grade machine. (I recommend buying a mobile workstation for professional modeling but these hybrid machines are quite prevalent in the consumer market, especially for students.)
They tend to generate a TON of tech support here because of the way they are set up from the factory.
Hybrid systems are built with 2 graphics processors. A low power graphics chip (typically Intel HD or UHD) and a high power graphics card. However…
Im not seeing any Citrix apps running.
theoutside
(Kyle Houchens)
October 10, 2023, 5:00pm
20
running or installed? just being installed causes the problem…
