@brian Twice recently when trying to start Rhino 7 WIP my system has displayed a message
with flashing in the background. Today it happened again and I had to use Task Manager to kill it.
Then I restarted Rhino 7 WIP and it said a an update was ready to load. So I let the update load, and then it restarted normally except for initially displaying a message about “Downloading profile ….” or similar.
Rhino 6 updates and loads normally.
SystemInfo from after the update:
Rhino 7 SR0 2019-4-17 (Rhino WIP, 7.0.19107.3015, Git hash:master @ 3f4726227d1aabe8784ea128620962016acccd15)
License type: Commercial, build 2019-04-17
License details: Cloud Zoo. In use by: David Cockey ()
Expires on: 2019-06-01
Windows 10.0 SR0.0 or greater (Physical RAM: 12Gb)
Machine name: ASUSLAPTOP
I’m familar with that page. The problem I’ve had is the driver on the computer is the one ASUS installed and the Intel software refused to replace it. I would get a message that I needed to obtain a new driver from the computer manufacturer (none available) or a message that the best software was already installed.
Today I successfully installed the most recent driver from Intel. I used Device Manager to uninstall the adapter after checking the box to delete the driver software. (Uninstalling the device without checking the box resulted in the old software being automatically reinstalled when the computer restarted.)
So far Rhino WIP 7 appears to be starting normally. I’ll see what it does after installing the next WIP update.
I don’t think this has anything to do with video drivers - though they also may have needed to update. @aj1 do you know anything about this empty dialog box?
No , I have to clic “switch to”, wait 1 min , then when lucky fetching license and it works.
Often , I have to go to running programs and close it then restart R7 wip.
Hi - sorry for being slow on this one but I’m not able to connect the dots here…
Are you saying that you get the “fetching license” message and then Rhino 7 starts normally?
Then, when are you getting the “Server Busy” message?
Could you take this one step at a time from the beginning?
OK so first Start R7 from desktop
nothing happen, wait 15 sec then “busy server” message pop up
Clic “switch to” ,then wait 30sec to 1min and “fetching license” window pop ,
2 sec later R7 start.
