Again no crash report dialog, this time while renaming a Layer:
RhinoDotNetCrash.txt (991 Bytes)
RhinoDotNetCrash.txt (1.0 KB)
Hi Lennart, Please type systemInfo in the Rhino command line and post your results. Thanks.
Hi Japhy, here are the results:
SystemInfo.txt (3.2 KB)
Thanks, can you disable the third party plugins (via Properties>Plug-ins) restart Rhino and try again?
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Mindesk\Rhinoceros\Mindesk.rhp “Rhinoceros® Link for Mindesk”
Please ensure you are set to high performance Soooo, you bought a laptop with hybrid graphics and rhino doesn't run right. READ THIS
@brian
Hi Brian, i’ve been rendering several passes without issue, but when finally turning on “Transparent Background” Rhino crashes with no report dialog poping up. I coundn’t get a picture, but was able to record it, video below:
PS: the same file will render with no issue with transparent bg on Rhino 7.
Rhino 8 SR0 2023-10-5 (Rhino 8 BETA, 8.0.23278.13003, Git hash:master @ ef9b91f9bd9105fc36db6b03c7d47d3fd68a6bc6)
License type: Commercial, build 2023-10-05
License details: Cloud Zoo
Expires on: 2023-11-19
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.12
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 2-22-2023 (M-D-Y).
- Windows Main Display is laptop's integrated screen or built-in port
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 8-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.99
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-4-2023
Driver Version: 31.0.15.3699
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp "Commands" 8.0.23278.13003
C:\Program Files\Rhino 8 WIP\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 8 WIP\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.0.23278.13003
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.0.23278.13003
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp "MeshCommands" 8.0.23278.13003
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.0.23278.13003
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp "RhinoCodePlugin" 8.0.23278.13003
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.0.23278.13003
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp "SectionTools"
Did you use task manager to force quit Rhino or did Rhino just crash and disappear on its own?
No, it closes on it’s own, I just moved the mouse around.
Hi @diegodx,
This crash bug has been fixed in the latest BETA version from the 13th of October. Please download and install from here: https://files.mcneel.com/dujour/exe/20231013/rhino_en-us_8.0.23286.01003.exe.
Let me know if it works for you in the new version.
Regards,
-David
Hey @DavidEranen, thanks for the reply.
Not crashing anymore, but not working as expected either:
Lastest beta release
new file with some geometry
new PB material
no lights
rhino automotive studio for all environments:
Ground plane ON = ok (object + ground plane)
Ground Plane ON + Transparent BG = render all white(?)
Ground Plane OFF + Transparent BG = no color in RGB channel
Hi @diegodx,
Thank you for the report - I see the problem too. A fix is going in and will be available in the BETA in next few days.
-David
