Over here the dim commands are causing a crash, either when the first point is picked, or if I try and cancel before I pick a point. I don’t get a crash report window either.
Thanks,
Sam
Thanks,
Sam
Hmm- so far OK here. Did you just get a WIP update and see this happening or did it start in a build that worked before?
thanks,
This is on 6.0.14294.17091, 10/21/2014, which my Update and Statistics -> Check now is telling me I have the newest available. I’m pretty sure this was working before, but I don’t recall if that was on a previous version, or I have somehow messed this one up.
That does look like being the most current public WIP. Unfortunately the next one has been delayed.
Are you getting the crash reporting system or error messages of any kind?
None at all. All I get is the Windows “Rhino 6 Developer Build has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.” but not the usual McNeel crash reporting window.
OK, I found it. As it still happened in 6.0.14316.5541, 11/12/2014, I figured I would dig a bit more and it turns out it was the name of the dimension style that was causing the problem. The dimension style I was using was named 100% - if I remove the % in the name it no longer crashes. Having a % at the end of the dimension style name seems to cause a crash. This is new in V6, V5 and below seemed fine with it.
Sam
Just a bump to make sure the steps to repeat the crash had been seen.
Thanks,
Sam
