Rhino Windows window scaling glitch
I have come into some trouble, whereby the the scaling of icons on the window has made them too big and cuts off some of the writing
Here is an example, as you can see in the boolean, Select surface or polysurfaces t…
Could someone please advise the best way to solve this issue?
Regards,
Harry
See if this helps:
https://wiki.mcneel.com/rhino/5/video/highres/toolbars_and_text_too_small_in_64-bit_rhino_5_on_high_resolution_screen
Magnificent!
All sorted, Thanks for your help
