My rhino5 software icons are extremely small in size. I have tried possibly everything to enlarge the icons but the size is not increasing. I am attaching a screenshot of the same. Kindly help. Thank you.
Hi Ankita - please see -
Does that help?
It looks like your DPI scaling level is at 300% with the default medium button size.
Do you use a 32" 4K monitor? Windows 10 recommends 300% on my 32" 4K monitor and 150% on my 27" 4K monitor.
A 32" 4K monitor with 3840x2160 resolution and DPI scaling level at 100%, the large size button is about 0.7cm x 0.7cm on the screen. It looks fine to me.
If the large button size is too small to you, you can lower the monitor resolution to 2560x1440 with DPI scaling level at 150% or below.
Thank you all for your prompt replies. I tried all the suggestions but it still did not work.
The PC I am using is DELL XPS 15. i7.
