Good morning, I was hoping to get some help with a model I am trying to import into Rhino from SketchUp. I was able to successfully insert the SketchUp model, (Saved as version 8) into Rhino using the insert option, keeping it as a block, using meshes. I then deleted it because I made changes to the sketchup model and when I went to insert it back into Rhino it is inserting the previous version of the model, with deleted geometry and no new geometry. I was wondering if anyone else has had this issue and what they did to fix it. I am using SketchUp Make 2016 and Rhino 5.0. Any help would be greatly appreciated. I’ve tried saving the file in different locations, changing the name but it still brings in the first version of the model.
Thank you!
