Hello.
I work with Rhino 4.0 and Sketchup 8 and run Windows 8 64-bits.
I am trying to import a simple volume from Sketchup into Rhino, but it does not work. Rhino says the import is successful. I assume it’s a matter of scale. However, both programs are set to work in meters. Where is the problem then?
Thank you.
Hi:
You’ll need V5 to import newer SKP mesh files. V4 had an early (2007) proof-of-concept Labs tool but it won’t read any of the newer SKP file formats.
Download V5, install it as an eval, and give it a go.
Hello. Thank you for your answer. I understand that import of sketchup files into Rhino 4 cannot work. I tried what you said and it worked indeed.
