Those options are water vapor, intensity, turbidity, etc etc.
Thing is I cant select the Rhino Sun, and modify these options. I dont like positioning a whole new Sun, as I have no idea where to put it or the angle.
I thus prefer to use the default Rhino Sun, but I want to have access to those options. Is it possible? Seems that you gotta select the sun and then those appear in “properties” tab. But I cant select the Rhino Sun because its nowhere…
you can access the sun properties, as far as I know only through the environment settings of Vray in this case. In order to access the settings, apply a texsky to your gi environment and choose rhino sun. Then you can alter the properties there.
After that you can either uncheck the map, or reduce the GI skylight value to 0 and the sky won’t contribute, but you still the changes to the sun remain.
I have just noticed that when I make changes and reduce the GI skylight to 0 so that the sky wont contribute, changes made to the Rhino Sun through the Rhino sun controls do not apply anymore. For example changing altitude and azimuth…
