In the drop down menu that shows layers, properties, etc the rhino sun option is nowhere to be seen, and accessing the panel through the render tab (sun logo) does not open a panel despite the command lines showing some activity.
Any insight into the matter would be great! Thanks much,
Jin
Also, there was an episode about 2 weeks ago where the toolbar settings began reverting back to default without my input, so I went through and deleted a .rui file, as per the online recommendations in regards to a similar problem. It fixed the issue then but things like this began happening not long after.
Maybe it’s an issue with that? I’ve tried uninstalling and reinstalling rhino multiple times since then but the problem has persisted.
Hi Jin - please try running Rhino once as an administrator, if you have that access on this machine - close it again then go back and start normally - is that ant different?
Sorry - how would I specify running it as an admin? I am currently running it from the “admin” account on this pc (the only other one is the public one)
Hm. It doesn’t show up in the panels docked on the right? Do you have more than one monitor? You might try testResetWindowPositions - does that do anything? I’m not even sure how it affects panels.
C:\Program Files\Rhino 6\Plug-ins\rdk_ui.rhp
Check it’s Properties (right click) and if it shows the control to Unblock it (On the top level page of its properties, I think, at the bottom) do that and hit ‘Apply’
