I’m trying to print drawings to pdf, however, each time I print them the lines come out very distorted. Line weights set to default (width 0mm), print output type = vector.
See attached images. Any help would be much appreciated.
Hi @dannyoconnor562
Not sure why no one has responded to this - usually someone from McNeel or another user will get back to you within hours. I don’t do a lot of 2D work, by initial my question would be: What PDF writer are you using? Also, run the SystemInfo command in Rhino and post the result here. If you can post a Rhino file (just containing the relevant geometry) that would make it even easier to trouble shoot.
HTH, Jakob
