Printing to pdf line weights
Hello!
I have been using Rhino 7 Layout (Mac) to do some architectural drawings. I have set the ‘print widths’ to the line weights I want them to be when saved as a PDF.
When I save them as a PDF (using the print - save as PDF ) the lines are all really thick/pixeleated. I don’t suppose anyone knows where I’m going wrong?
Thank you!
Hi Thomas - make sure you are printing as vector and not raster.
Hi Pascal,
I have just tried that but still isn’t working. Any other tips?
Thank you!
T
Hi Thomas - if you can send a simple example file that shows the problem, as well as the pdf output that you get from it that would be helpful .
Hi Thomas -
Have you tried creating a PDF with the Rhino Export or ExportAll command?
Hi Wim,
Thank you, sadly that hasn’t worked either.
T
Is there a setting I should have ticked on/off?
In ‘Print display’ I have:
state: On
Colour: Print
layout linetypes: unticked
Thank you for all your advise!
