Hi, I’m using Rhino 6 and for some reason I do not see the “Rhino PDF” option available in my print settings. I’ve currently been using Adobe PDF but that takes forever and even manages to crash the program if the file is over 600MB. Is there anyway to troubleshoot this?
Hello - what is that last PDF at the bottom of the list- does that work? Can you run SystemInfo in Rhino and post the results?
Hi Pascal,
The very bottom PDF works for files that are not as massive. The lower PDF option does crash if I try to export/print from a larger file.
System Info:
Rhino 6 SR1 2018-2-6 (Rhino 6, 6.1.18037.13441, Git hash:master @ 5a33e6871b94d32ba552468218cef0ad8d3d1263)
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
GeForce GTX 1050/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 445.87)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: NA
Driver Version: NA
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Users\mariy\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino6.Plugin”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 6\Plug-ins\NamedPositions.rhp “Named Position”
Hello - please go to the Help menu and choose ‘Check for updates’ and install the current service release - we are on 6.25 or so now, you have 6.1. Let’s take it from there once Rhino is updated.
