For the past few days, my Rhino PDF won’t print if any of the detail is in Arctic or Shadded display mode. I tried to change the display mode to wireframe and it works. Even if the Rhino file is 2 mb, light, it just won’t print and is just stop responding at all. I down-saved to R6 and have no problem with the same file in R6.
I have tried to reinstall Rhino but no luck. What else should I do to check what’s is causing this issue?
Hi @theoutside I did. My Nvidia driver is up to date. I did another test. I got a PDF printed on a smaller sheet of paper. 11x17. For some reason it just doesn’t work on my E1 layout…
Hi @stevebaer I am on the latest released. Reinstalled but no luck. I vaguely recall the problem started after I updated my nvidia driver about 10 ago. Could that be the problem?
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 9-13-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.12
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-13-2021
Driver Version: 30.0.14.7212
Z-Buffer depth: 24 bits
Total Video Memory: 10 GB
S:\Dropbox-E-Library- Set Design resources- Rhino\Plugins\XNurbsRhino 5.0\XNurbsRhino 5.0\XNurbsRhino.rhp “XNurbs”
C:\Users\hogan\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21231.815
C:\Users\hogan\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot10RhinoPlugin (ccedd9da-83b9-429a-aec5-8ec90b85fe67)\1.0.0.0\KeyShot10RhinoPlugin\Rhino 5.0\KeyShot10RhinoPlugin.rhp “KeyShot10RhinoPlugin” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Users\hogan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.3\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.3.0
C:\Users\hogan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.1\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.1.0
Did you update those drivers because of some problems with Rhino?
I suppose you could always try both a clean install of the drivers after making sure that Windows is on the latest update or using an older driver but I would start with disabling all the non-standard plug-ins that you are running.
I updated the driver because the system notified me nothing was wrong in Rhino before that. Tried to clean install an up-to-date nvidia driver and still no luck. Also disabled the plug-ins. What should I try next?
