Hello, I have an issue with exporting Rhino PDF from Top view, when I click print which would pop up the window where I want to save the file as usually as it works. But now it seems something is wrong and I do not have any pop up when clicking on print button. Nothing happens. Anyone have dealt with same issue?
Hi Zhaidarbek, Lets start troubleshooting by running SystemInfo in your Rhino command line.
https://discourse.mcneel.com/t/please-read-this-if-you-are-logging-a-bug-or-issue/173971/3
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Educational Lab License, build 2023-12-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 10-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.58
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-4-2023
Driver Version: 31.0.15.3758
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Program Files\Doliwa Workshop\Rhino Nature\Rhino Nature.rhp “Rhino Nature” 1.0.3.33161
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
The next for troubleshooting is to disable 3rd party plugins and try again. You can do this in File>Properties>Plugins (sort by 3rd party) then uncheck and restart Rhino.
It says “Failed to create instance of VBScript scripting engine.”
After I click Ok to that window it freezes the whole file…
When I click File > Properties then the Failed window pops up
I have no Idea what is wrong, just yesterday everything was completely ok without trouble
Lets do a repair install.
Go to Window>Add & Remove Program Select Rhino 7 and modify the install> Repair
Oh gosh I wanted to avoid that but if there is no other way then it is what it is. Does the repair install removes settings and plugins?
Was there anything new installed (plugins, windows updates, anything…) since yesterday?
Repair will remove custom settings, the plugins will remain.
Yes there was a windows update. Ok thanks I will try repair install. Will let you know if it worked.
Repair install did not worked. Cannot print export Rhino PDF and also same issue with the File Properties
If you open Rhino in Safe mode (Type Rhino 7 in Safe mode in the Windows start) can you access the properties and disable plugins?
Safe mode disables plugins and video drivers, you will need to agree to some of the default ones to get the properties up.
Ok I found a solution. I just copied everything that I had in this file into new file and everything works. No idea how but I am not complaining. Thank you very much for your time Japhy.
