Everytime I go to a specific layout sheet I created over a week ago, rhino keeps freezing, PLEASE HELP! @bobmcneel
please help! @Japhy I am uploading the file to you guys now
now when i open, nothing is there
it’s a very large file
Please run SystemInfo in your Rhino command line and past the results. Thanks
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commercial, build 2024-04-10
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) UHD Graphics 770 (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.5186
Secondary graphics devices.
NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 4-2-2024 (M-D-Y).
- Secondary monitor attached to adapter port #0
ATTENTION:
Desktop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
An accelerated graphics device exists and is attached to a monitor, but it’s not being used by Rhino.
- Recommended: Use Windows’ Display Settings to configure the monitor attached to the NVIDIA GeForce RTX 4090, to be the “Main Display”.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.5186
Driver Date: 1-18-2024
Driver Version: 31.0.101.5186
Z-Buffer depth: 24 bits
Total Video Memory: 128 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.6.24101.5001
just got a new computer, had AMD – had a bunch of crashes and then just like 4 days ago switched to INTEL
It looks like you are plugged into the Intel
how do I switch this?
Generally you can follow these directions, but if you are having issues you may want to look at Device Manager and see if your Video Cards are working correctly.
can both monitors be plugged into the nvidia?
looks like it depends on the hz
perfect, I love it
I just uploaded the file to you guys, can you please help me get my work back. it’s all missing
just found some bad objects in the file - hoping this was it
thank you for your help, no longer crashing on layout
I lost some work but I had a backup file… I think I’m good to go! Thanks @Japhy !!
Hi @Japhy I have been working with microcenter to understand what is going on. brand new custom build - this shouldn’t be happening. I AM able to plug both monitors into my graphics card — and it’s been working great… however, when working in rhino - the system seizes on me and I can’t do anything no ctrl+alt+delete. and happens completely random!!!
You can’t control+alt+delete? That sounds like a hardware issue.
If Rhino freezes and you can access the task manager please create a crash dump and send it to us.
