My rhino 7 freezes my whole computer whenever I try to model or move objects. Looking for assistance as to why my whole computer freezes and not just rhino.
Run the Rhino command SystemInfo and post the results here.
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001, Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
License type: Educational, build 2021-08-10
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 8-27-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.96
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-27-2021
Driver Version: 30.0.14.7196
Z-Buffer depth: 24 bits
Total Video Memory: 24 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21222.15001
Hi -
A system-wide freeze points in the direction of a serious issue with your hardware.
Does it also happen if you start Rhino straight after a reboot, create a simple box and move that box?
It’s happens at three different points, one was when I was rotating part of a cube in the late stages of my model, one was right at the start, the other was when I used the pipe command
Hi - have you checked if there is anything blocking any of the fans in the computer?
You could also try a clean install of the latest drivers for the GPU with the following instructions:
Make sure to include step 4 of the uninstalling process!
