"Rhino.Inside for Autodesk Revit Setup Wizard ended prematurely"
Dear all,
I have a hard time to install Rhino.Inside Revit.
I downlaoded the installation file.
But each time i have the pop up window.
picture 2
If someone had the same issue and know how to do, please send me few hints.
I googled it but there is no indication about this issue.
Thanks in advance for your help,
David
Hi David, This a new one. Can.you open Rhino and type SystemInfo into the command line and post the results here please?
Thanks
Hi Japhy,
Thanks for your quick reply. Here is the SystemInfo reslut:
Rhino 7 SR24 2022-11-4 (Rhino 7, 7.24.22308.15001, Git hash:master @ cb2ad12922ceb989b185972675bb705a00abb97d)
License type: Éducation, build 2022-11-04
License details: Cloud Zoo
Windows 10 (10.0.19042 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP (Hosting Remote Desktop session)
Primary display: Microsoft Remote Display Adapter (Microsoft) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
> Remote Desktop display device with 16 connection(s)
- Windows Main Display using connection #0
Primary OpenGL: NVIDIA Quadro M2000 (NVidia) Memory: 4GB, Driver date: 9-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 392.68
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-6-2021
Driver Version: 23.21.13.9268
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.24.22308.15001
This graphics configuration is the issue. Remote Desktop isn’t supported.
Effectively, the fist time I tried to install Rhino.inside was with my remote connection (office computer from home).
But i also tried directly from my office and it didn’t worked. Is there a Trigger effect? Meaning after it don’t work?
I also can send you the SystemInfo on monday.
Thanks for your help! :slight_smile:
Thanks, more details about your environment are going to be key here.
Japhy,
This is the SystemInfo from my main desktop.
I don’t see the diference.
Do you sudjest me to uninstall Rhino and Install it again?
Thank you very much for your help,
Regards,
David
PS. Don’t be surprised to receive an email from Europe support (Augustina)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
I believe this is due to the display configuration. Rhino doesn’t support Remote Desktop.
  • Windows Main Display using connection #0
  • There are no monitors attached to this device!
Thanks Japhy,
You are certainly right. Evene if Rhino works fine for me since i installed it remotely.
I understand i can only use it from my local desktop.
But could you help me how to solve this issue? I really need to install Rhino.Inside
Can I send you my systeminfo via cmd ? I don’t know if it is wise to display it in a forum…
Feel free to ask me more details if needed.
Regards,
David
I uninstalled Rhino and instal it again. And that is the solution.
Thank you for your help
This is my new Rhino System Information:
Primary display and OpenGL: NVIDIA Quadro M2000 (NVidia) Memory: 4GB, Driver date: 9-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 392.68
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
