We installed Rhino.Inside Revit in a couple of our machines but we keep getting the below error…Keeps asking to download latest version but we have done that several times already.
The version for Rhino.Inside Revit comes as 0.0.0.0 which is weird
If this does not work, The code just looks at registry (RegEdit) here HKEY_LOCAL_MACHINE\SOFTWARE\McNeel\Rhinoceros\7.0\Install for a value called Path that contains the Rhino 7 WIP installation folder. What does that value contain in your case?
We checked in here but for some reason we cannot see Rhino 7 in the registry or the c:drive program files (see image below)
We followed all the steps but not entirely sure what’s wrong. I can open Rhino 6 but if I try to open 7 it opens 6 again and I get an error (see second screenshot below)
Well at the moment I’ve tried as per my screenshot below, as I don’t have a Rhino 7 WIP shortcut on my desktop. So just do that and try and open it normal or as an administrator but either way Rhino 6 opens on and not 7 WIP
Hi Wim, we did as per your post above and now it works in my computer. Thank you for that
We did came across another issue though, in one f my colleagues machines we got the below error when trying to open rhino.inside. I believe this is got something to do with Pyrvit as he has it on his machine. I don’t have PyRevit installed so I think that’s why it worked for me. Do you know if there is a solution for this?
Please open the PyRevit about box on the computer that is not working and take a screenshot. Normally a newer version of PyRevit is needed to fix the problem.
