hi everyone! ![]()
i can’t start rhino inside, does anyone know why? i can’t understand what’s going on, cuz i’ve checked all your suggestions, but i couldn’t manage to make it start.
also grassopper doesn’t show rhino inside menu bar…
thanks a lot
hi everyone! ![]()
thanks a lot
What version and service release of Rhino do you have? Is it 7.1, 7.2? Look in the Rhino 7 About box.
Version 7
(7.4.21067.13001, 2021-03-08)
Licenza lab educational
The interface on where the Rhino button in Revit might be a bit older.
There is a new build Rhino.Inside.Revit attempts to resolve the loading and runtime errors in Revit.
Download and install to see if it resolves all the load problems.
Because this is a major change, it does require additional steps to install properly:
Thanks
hi,
the problem is not solved I can not activate rhino inside from revit 2021 and on grasshopper the components are not loaded. Am I the only one who is facing this problem?
Thanks
@pietro.luis Take a look at this as well please Rhino Inside Revit WIP Build Expired - #4 by kike
