Error loading Rhino 7 inside Revit
HI guys,
I installed rhino 7 (7.0.20314.3001, 09.11.2020) after the rhino 7 WIP. The problem is that the rhino inside revit still is looking for the rhino 7 WIP.
here a screenshot of the error.
grafik
any idea if reinstalling the rhino inside revit pluging will sort out the problem? any other suggestions?
p.s. the rhino 7 works wells
Hi -
From that screenshot, yes, that would probably solve it. The current version that is mentioned on that picture (0.0.7574.4063) looks to be referring to the plug-in, not to Rhino.
hi @wim,
thanks for the reply. I reinstalled the plugin and the rhino 7, bu the problem unfortunately is still there. Any suggestion on how to sort it out? I would like to avoid to format the pc…
thanks in advance
Hi Federico -
I see that I might have expressed myself poorly. Did you click on the Check for updates... button and got the latest version of the plug-in? You should now be running version 0.0.7643.31783.
HI Wim,
yes thi is exactly what we did. I downloaded the latest plugin on the 9th of December and reisntalled it with the latest rhino. but the error message is still there, the revit bar is showing rhino 7 not rhino 7 wip as before. and after all these, the error mesage is always the same. is the error because there is a new rhino.inside plugin issued after the 9th dec 2020?
Hi Federico -
Does that mean that the “Days left” dialog box is still saying that your current version is 0.0.7574.4063?
hmmm. I’m not sure why you mention December 9th. From what I can see, the latest WIP was released on December 4th.
At any rate, either @kike or @eirannejad should know how to get out of this one.
@Federico_Giacomarra
Current version: 0.0.7643.22707 (12/4/2020 12:36:54 PM)
Please download from here and make sure you have this verison installed
Also make sure there is no %PROGRAMFILES%/Rhino WIP directory on your machine
Ok!!!all good!!my fault for some reason at some point I tought I needed adminstration permission, which is not at all the case. So i installed the plugin as user and all is good now!! thanks again guys! I am finally ready to put my hands on rhino inside !
