Is there a way to create structural rebars through grasshopper in Revit? I was able to make the 3D, and it says it’s structural rebar type, but there’s no information - no length, diameter, nothing, not even the correct parameters so I could write it in. Now it acts the same as if it was modeled in place in Revit. I would like to create schedules in Revit after, but can’t figure out how to make it work. I’m new to grasshopper, so maybe I just can’t find the right component or plugin. I’m hoping you can help me out!
Hi P111,
We do have a feature request for Rhino.Inside.Revit Rebar components in the queue, no native components are available yet.
You can try the funbim node pack, available for download from food4rhino, which has a reinforcement node that you can try
funBIM for Rhino.Inside.Revit | Food4Rhino
Hello @sky1,
Great work! And thank you for sharing!
Whether you have plans to develop further the Structure panel?
Particularly interested in “Create Rebar from Curves and Shape”, setting layouts (Maximum spacing, Fixed number, etc) and “Create/Set rebar shape ID”?
Br,
Sergey
Hi @Zezza
Are you looking for something like this?
Hello @MSAwan,
It is difficult to say without testing, but from the first glance, though it looks promising, it does not cover all the necessary functions. Ideally, I would like to have “Structural Design” package with all its functions from Dynamo, but in Grasshopper. The best possible way to have it as a plugin, and not via scripting inside of GH for all these components.
Can you tell me what are the main nodes in this structural package?
You Can also control the shapes using the Parameter Option.
I have attached the code for your reference.
RebarScriptgh.gh (14.5 KB)
