I was wondering if there is a component that can create rebars in Revit by curves? I am struggling using rhino inside to create rebars from grasshopper scripts.
Looks to be accessible. Do you use Revit Structural Rebar in your current workflow? What about your current GH Scripts is creating difficulty? What is your ideal workflow?
Yes. Revit structural rebar is used. In the current GH script, the rebars are modelled by add direct shape by geometry with structural rebar as category, curves created in GH, and defined material is steel. The challenge is then to get Revit to detect the rebar shapes and the rebar diameter and assigning a host element. Maybe an idea is a component that can create rebar from: part (host element for the rebars), shape of rebars and attributes.
is there any updateds on such a component?
