I have been dealing with a users machine where we are just unable to get rhino.inside to work in Revit 2020 (we have extended support for the 2020 version). The plugin shows in the ribbon, but on trying to launch, revit hangs, the 'Preparing Plugin For First Time Run; dialogue box appears, this then hangs and after a few moments Revit crashes out.
System Information in Rhino gives:
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Commercial, build 2023-12-12
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
Primary OpenGL: NVIDIA Quadro T2000 (NVidia) Memory: 4GB, Driver date: 11-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.09
> Integrated accelerated graphics device (shares primary device ports)
Secondary graphics devices.
DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 4-16-2020 (M-D-Y).
> External USB display device with 2 adapter port(s)
- Secondary monitor attached to adapter port 0
- Secondary monitor attached to adapter port 1
> External USB display device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-2-2023
Driver Version: 31.0.15.4609
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\rus29590\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleConnectorRhino” 2.17.1.13214
C:\Users\rus29590\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.0\Substance.Win.rhp “SubstanceImporter” 2.0.0.0
C:\Program Files\SOFiSTiK\2024\SOFiSTiK Rhinoceros Interface 2024\sofrhino.rhp “SOFiSTiK Rhinoceros Interface 2024”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
Revit details are:
20.2.90.12
20220517_1515(x64)
2020.2.9
If I check eventviewer I see:
Rhino and Revit have both been reinstalled, and the Rhino.Inside plugin was installed from the latest available on the wbsite.
Any suggestions for this one please?
