Rhino Inside Crashing Revit
I’m using Revit 2022 and every time I run Rhino inside Revit, it crashes Revit without any warning. Anyone else had this issue and found a workaround?
Thanks
Hi Has, There are several possibilities here, most likely a plugin conflict.
Can you open Rhino on it’s own and run SystemInfo in the command line and post the results here? (video card and Rhino plugin info) Thanks
Typically its an outdated version of Enscape or similar plugin.
Hi @Japhy , thanks for the quick reply. My Enscape for both Revit and Rhino are up to date.
This is the System Info result:
Rhino 7 SR20 2022-7-12 (Rhino 7, 7.20.22193.09001, Git hash:master @ 9b19bfdb8c343dd6fa8df3514068defd72273d6f)
License type: Commercial, build 2022-07-12
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 8-4-2022 (M-D-Y).
Primary OpenGL: NVIDIA RTX A5500 Laptop GPU (NVidia) Memory: 16GB, Driver date: 11-2-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 526.67
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-2-2022
Driver Version: 31.0.15.2667
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Users\mhasafa\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22290.1357
C:\Users\mhasafa\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
Try disabling the Revit Addon.
It appears that Enscape is on 3.4.x, is that the version you are running?
