Copy from Windows Rhino crash Rhino.Inside
Hi, my friend runs into this issue that every time a Rhino object is copied from Windows Rhino will crash Rhino.Inside Revit, even it is a simple cube. We have tried very thing we can think to solve this issue, like reinstall Rhino, and update Rhino.Inside (1.14), but it doesn’t work.
I have attached the RhinoDotNetCrash.txt, hope the issue can be identified. Thank you in advance!
RhinoDotNetCrash.txt (3.1 KB)
Hi @hali,
Have your friend run Rhino’s SystemInfo command. Then post the results here.
What version of Revit is your friend using?
Thanks,
– Dale
We removed all the Grasshopper plugins and updated Revit.Inside to 1.15. It temporarily solves the issue. I will be back, if the issue shows up again after reinstalling the Grasshopper plugins.
We are on Revit 2022, here is the systemInfo, but this is after the plugins removing.
Rhino 7 SR30 2023-6-12 (Rhino 7, 7.30.23163.13001, Git hash:master @ f695e494df78377a81b2b95edb99c6067e324b33)
License type: Commercial, build 2023-06-12
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 64Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 9-2-2022 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA RTX A2000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 6-10-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.25
Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-10-2023
Driver Version: 31.0.15.3625
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22353.1023
C:\Users\MShoufan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.30.23163.13001
C:\Users\MShoufan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
