Hi All,
I wanted to run the Rhino.Inside Revit with the new Rhino 7 release version but it doesn’t seem to work.
When I open Revit and click the Rhino toolbar icon a couple GH errors pop up saying e.g. "The CurveComponents Component Library was built against a different major version of the Grasshopper SDK: LocalSDK = 6.3.18090.471 Referenced SDK = 7.0.20314.3001. As a result most of the GH features are missing when I activate it with the Grasshopper toolbar icon and it seems to be an old version (1.0.0005) as well (no idea where it gets this version, I couldn’t find it on the computer).
When I open Rhino with the Revit toolbar icon and manually start GH with the Grasshopper command inside it everything seems to start up well (1.0.0007) but there is no Rhino.Inside components so I assume this is not the correct way of doing this either.
So I assume this error comes from Rhino.Inside still being based on Rhino 7 WIP (6.x)?
Are you going to release a Rhino 7 release version installer soon?
Rhino.Inside Revit: 0.0.7628.14364
Revit: 2019.0 (20180216_1515)
Windows 10
Thank you very much
Best regards, Frank
