Hi, I’m currently using Rhino 7.38.24338.17001 and I want to use the plugin Rhino.Inside.Revit for Revit 2024 and/or Revit 2025 but I can’t manage to find an installer compatible.
When I download & install from the official website or through food4rhino, the plugin states it’s only compatible with Rhino 8.
Is it possible to get a version compatible with Rhino 7 ?
Can you take a screenshot of the issue you encountered?
Usually, after installing RIR, running Revit will display a prompt like the one below, asking you to choose between Rhino 7 or Rhino 8.
