Rhino version 7.18 not working with Rhino Inside
I get this error when launching rhino inside in revit ?
Should i get another version of Rhino 7 ?
Hi -
7.18 is very old. As you can see in that dialog, the minimum version is 7.28. The current - final - version of Rhino 7 is 7.38…
Can i get a previous version of rhino inside ? Will that work ? I have Revit 2019.0
Hi Bilan, Its recommended that you update your Rhino 7 and have the latest Rhino.Inside.Revit
@wim Hi, i was able to install the right version but the REVIT tab does not show up in Grasshopper. Here an image. I open Rhino and Grasshopper from the rhino inside add-on in Revit.
Grasshopper has zero revit components ? I open Rhino from Revit.
Hi Bilan,
Please run SystemInfo in Rhino and post the results as well as the About info Revit. Thanks!
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Commercial, build 2024-12-03
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9664
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9664
Driver Date: 6-1-2021
Driver Version: 27.20.100.9664
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files (x86)\Evolute\EvoluteTools LITE for Rhino 7\EvoluteCoutHook.rhp “EvoluteCoutHook”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Users\bilan\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
This is well below Rhino and Revit’s system requirements.
This in itself will not cause the RiR ribbon to not show up, this is typically a plugin conflict.
You are also many years behind in Revit 2019 updates. https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/5GNFMLzu78sqh6NxXGvU1u.html
This is noteworthy as well.
