Rhino inside Revit - Direct Shapes geometry is empty
Hi there,
Fairly new to rhino inside revit and grasshopper.
i am trying to push rhino geometry into revit and am stuck with the direct shapes node giving me this error
  1. DirectShape geometry is empty.
    is anyone able to give me some direction on a fix?
    thanks!
The orange wires indicate they are empty. Check that you indeed have objects on 4_Roof and hit the update button or right click and change it to auto update.
yes i do have objects assigned to the layer
If you input a Value List into Elefront components they will auto-populate, perhaps there is a misspelling?
no miss spelling, even with the value list it still comes up with geometry is empty
Hard to help from an image in this case.
apologies, here is the GH file
Direct Shapes Issue.gh (19.3 KB)
If you can also upload a rhino file with sample geometry on that 4_Roof layer so we can have a look
I am receiving the Direct Shape Geometry is Empty error too.
I believe that all of the geometry is going through, but I have not thoroughly verified this.
What is interesting is that 107 objects are received and then it creates 109 Direct Shapes, presumably the two additional Shapes are the empty ones. Thoughts?
GH and Rhino attached
Direct Shape Empty.gh (29.4 KB)
Direct Shape Empty.3dm (5.1 MB)
Hi! Another useful tool for working between Rhino and Revit is the plug in BEAM. This helps transfer and integrate complex designs from Rhino into Revit, allowing for seamless collaboration between 3D modeling and BIM workflows. This can replace but also work with Rhino inside Revit.
More information here: https://www.mksdtech.com/
