This change has consequences on Rhino plug-ins as well as Revit Add-ins built on older frameworks.
One of the issues we are tracking is Rhino UI behavior. Any adjustment to the layer panel for instance will jump around, going to Rhino 8>View>Window Layouts>Default Window Layout and resetting to defaults gets it back to normal.
Due to Revit being in .Net 8 only Rhino 8 can be supported.
Thanks in advance for reporting any additional issues you may come across.
As always please check the release notes for the latest updates
hello. I tried the rhino inside revit wip version in REVIT 2025. Thanks for the update on revit 2025. I just turned it on and I see a small problem. When using the wip version, the mouse wheel button does not work in Rhino. But it works in Grasshopper. Just mouse wheel click doesn’t work. Zooming in and out is possible.
Rhino.Inside.Revit will still be a single installer that has the latest Rhino 7 & Rhino 8 updates. The only reason Revit 2025 won’t work with Rhino 7 is the .Net 8 change in Revit is a big change, it’s not ‘if you want the latest RiR components you must use Rhino 8’.
hello. I will send you a copy of the systeminfo you mentioned. If you adjust the size of the layer window and task button areas on the left and right, it does not work well, unlike rhino8.
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.4
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 1-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.65
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-12-2024
Driver Version: 31.0.15.4665
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
I was trying to install it, but Revit 2025 won’t show ‘Rhino Inside’ on the top bar. I already installed the plugin version RhinoInside.Revit_1.20.8836.21283.msi
Hi Japhy, thanks for the link for the 2025 WIP! I’m experimenting with it heavily during these days.
I have a couple of issues with RIR for 2025. Where can I discuss them?
(Value Picker freezing on model layer, an error installing the last daily build etc.)
Thanks in advance,
Roberto
As regards the RIR 2025 WIP installation it seems that this last daily build is trying to install inside Rhino 7 (which is no longer present on my system). The previous build installed and was running correctly.
Also seeing that the latest Daily Build fails in Revit 2025. Any updates on how this could get working? Did you say it require Rhino 8, @Japhy ? (Cool name by the way).
