Hi Cody. Thanks!
Revit 2025 switched its .Net Version (8), Rhino 8 switched versions too (7), but we’ve got it going and should work with our latest. Rhino 7 (.Netframework 4.8 is not supported in Revit 2025)
Hi Cody. Thanks!
Hello could I also get a link
can I also get the link,please? thank you!
Can i get the link to the WIP also
can I also get the link, please ? thank you !
Sent. One install not going well but other than that we haven’t had any reports of any new UI issues (.Net change related)
Can you please send me the link? Thank you in advance.
Hi Japhy,
Like Arshad, I just tried installing RiR for Revit 2025 and have the same issue of no toolbar. It’s my first time trying to install on any version. I have Rhino 8 already. Are you able to send me an installer for the daily build?
Sent you the latest. Let us know if this doesn’t load for you. Thanks
Can you please send me the link? Thank you.
Hi Japhy,
Like Joe and Arshad, I just tried installing RiR for Revit 2025 and have the same issue of no toolbar nor any pop up to “Always Load” . It’s my first time trying to install on any version. I have Rhino 8 already. Are you able to send me an installer for the daily build?
Hi, can you sent it to me too? Thanks in advance
so is there no way to make rhino 7 functional with revit being 8.0?
Hi, I’m also with only Revit 2025 installed. Can you send me the link? I also teach a class of students, and some of them will use the rhino.insde in our final exam. Most of them uses older versions of Revit. I don´t think we will have any problems with that, but in case some of them is working with Revit 2025, can I call you for help. Is this final release going public any time soon?
Thanks a lot
Hi Ffribeiro,
The current Service Release installer + now installs in Revit 2025. So anyone with a previous Revit version has access. Do you still need an installer?? Everyone should feel free to contact me with questions at anytime.
I just tried to install in Revit 2025 and nothing happened ( the installer runs to the end but nothing is installed in Revit 2025) Also, there is no Rhino.inseide.revit insalled in windows applications list. I do not have an older version of Revit installed, so I couldn’t figure out how to install it.
I Downloaded from this link:
Sent, 1.22.8906.14842 is the minimum installer for 2025. That will become the default installer here in a few more weeks.
Hi Japly. Could you please send it to me too? best regards.
