I just saw that Revit 2022 can now import Rhino .3dm files directly.
I don’t have a Revit license and have already used up a free trial in the past. Has anyone tried this?
Can you now cut sections, dimension and material tag Rhino geometry in the Revit model? I know in the past, importing .SAT files didn’t allow this - you could see and select the Rhino geometry, but you couldn’t document it easily. Or, is the only way to do this is via Rhino Inside Revit plugin?
Thank you
