Anyway to import a 2022 Revit file into Rhino....?
I only have 2020 Revit and it won’t read it.
Brian
Are you using Rhino 7? Do you have a Revit License?
There is Rhino.Inside.Revit… Rhino.Inside®.Revit
Rhino.Inside.Revit will allow you to get just what you need out of Revit, Elements from its linked files etc, granted there is a learning curve but if you have a clear process I can help get you going.
The old school way is to export your 3D revit view to DWG 2018 or below and import/insert into Rhino.
The main problem is I don’t have Revit 2022, I only have 2020 and it won’t read or import a 2022 file format. All I need from the file is the 3D dwg but I can’t open it.
Brian
Have you had your 30 day free trial of Revit 2022?
Looks like autodesk has came up with a token system where you can basically pay $30 a day to use revit. That will be our cheapest option because all I ever use it for is to pull the cad files out that I need and I can do that in a day or two for most projects. We own acad 2020 and the full 2020 building design package which includes revit, autodesk was going to force us to give up our license which we own outright and trade it in on a subscription based service. That ain’t happen.
Brian
