Hi everyone,
I have a huge problem in visualizing/rendering a model I created starting from an AutoCad file (probably) generated froma GPS survey. Even if I purged the basefile, even if I erased all he elements that could create problems during modeling, the result is that all the extrusions (I usually model extruding planar curves, as I start from an imported CAD file) are bad, kinky, not fixed.
I’ve tried to adjust the mesh parameters but it doesnnt work, I tried to export & import in different formats (like OBJ, prevuois Rhino versions, DXF, DWG) but I can’t fix the problem.
I attach two images, the first one in Ghosted Visualization Mode that displays how the model sghould be, and the second in Rendering Mode that displays the visualization error.
I’m desperate!
Thank you in advance to all
Caterina
