I’m using win10 on a desktop and recently installed rhino. But every time I try to launch it, it immediately crashes and shows this message “Rhino encountered a problem and need to close”. I tried Rhino 7 and Rhino 6 and both crashed. Same results in Safe Mode. Does anyone have a clue what may caused this?
Likely Hardware incompatibility, can you share your Hardware info?
Also make sure your system meets the minimum requirements:
Hi, thanks for the reply.
I’m running AMD R5 3600 and Nvidia 1660s. I updated the drivers for both. 32g of ram etc, the setup should be fine for Rhino. I’m using 170hz monitor so DP cable.
Make sure your PSU can provide all the power your computer needs.
