I also have Rhino 6 on my computer if that helps.
I’ve seen other forum posts that say to open it in Safe Mode, but I do not have a Rhino 7 Safe Mode, I only have a Rhino 6 Safe Mode.
You need to update your Intel HD 630 GPU driver, Rhino startup fails due to OpenGL troubles. Additionally it is probably a good idea to update to Rhino 7.2.
You can right-click on your Rhino 7 shortcut, open properties and then add /nosplash to the command that starts rhino.exe (remember a space between the two).
Once you have done that run Rhino 7, and, assuming it starts now, run the Rhino command _SystemInfo. Please post the results of the command in a reply.
