My laptop seems to have an issue with Rhino 5, I run a windows 10 software on a MSI GS40 Phantom Laptop. It’s strange because when I first downloaded and installed Rhino there were absolutely no issues for the first time. Today, I’ve just received a report saying
“Rhino has encountered a problem and needs to close” along with a send error report
Tried updating my drivers, tried to run it on safe mode, 32-bit, 64-bit, none of it works
computer is definitely a high performance one with 16gb ram with an intel 530 HD driver as well as a NVIDEA GEFORCE GT970M one.
Processor is an i7 skylake 6700-hq 2.70 GHZ
I’m quite nervous because I need Rhino to help with an assignment for my university and it’s due pretty soon! It’s never happened on a previous laptop I had (also updated to windows 10 before I switched), only this one…
Tried re-installing it as well, no dice
seeing if it could be anything to do with virus and double checking the outdated softwares to see if theres anything else I can do
If it crashes in safe mode you won’t be able to check which GPU is used. I’m not on a PC at the moment but I think you need to dive into the driver settings for the NVIDIA card. If you search here on discourse, I’m sure you will find some information about this.
@Timothy_Huang found Nahimic audio software coming on the MSI laptop caused Rhino to crash. Disabling its application makes Rhino stop crashing. Thanks for sharing the information with us.
I seem to be having the exact same issue, tried reinstalling and everything with no luck…
I am running the latest version of rhino 6 for windows, and my setup is
laptop hp omen 15-ce0xx
windows 10 home 64bit
16gb ram
intel core i7-7700HQ
GeForce GTX 1050
everything updated with the latest driver
The only thing that I can point out is that I’ve had audio problems as well, which I tried to solve by reinstalling the intel graphics driver since it contained audio drivers as well, although my driver is realtek high definition audio, and for some reason it wasn’t showing up at all in the list.
Reinstalling the video driver didn’t solve the missing audio, but realtek somehow reappeared on its own after a few days, now the audio works but rhino doesn’t anymore…
Hello - if you are running V6, please run the SystemInfo command and post the output here. Does Rhino start in Safe Mode (Windows Start menu, type ‘Rhino 6 in Safe Mode’)?
Please run Windows’ Device Manager and expand the Display Adapters section.
I suspect there will be two; your nVidia GeForce and also an Intel somethingorother.
Right-click on the Intel, choose Properties and click on the Driver tab.
Please send a screenshot of that dialog.
I’ve just disabled my Intel graphics on my laptop because the switching between Nvidia and Intel was causing issues with my ICEM Surf - but now Rhino will only start in safe mode. Does Rhino need the Intel graphics to be working in order to start normally?
I think so, but I’m not a display developer.
As part of how Windows works, I think Windows control some of the interface display and uses both the Intel and nVidia adapters.
It may be possible using a nvidia tool to specify which display adapter an specific application uses.
You might see if you can find the tool and configure it to use the nVidia adapter for Rhino instead of letting Windows do the switching automatically as is usually the case.
You were absolutely right, that was an old driver! And now everything seems to be working perfectly, so thanks a lot! I would never have guessed it since I had just installed it and it seemed to be the latest…
Thank you very much, have a great day!
