first sorry for my English, I’ll do my best to describe it as best I can.
Today I install Rhino 6 Trial version for 90 days. Installation went well. But when I turn on the program, either my windows get black or I can’t create something in the world at all (I don’t even have to change the angle in perspective with the help of the mouse). For example, I can only click on the rectangle but when I want to place him into the world nothing happened.
I’m afraid my laptop can’t fully run Rhino. But it manages more demanding programs such as Photoshop, Illustrator, InDesign and with a few problems 3dMax too. And if this version fails to run, is it possible to download an older version? Could someone help me, please?
Are you able to type the command SystemInfo in Rhino even though the windows are black? If so, please copy/paste the info obtained here. (you can also do this in safe mode).
That is a pretty old system though - 2012 or so - not sure how well it’s going to work. The latest Nvidia graphics card driver is from 2018, I would get that and install it if possible.
Those programs are actually far less demanding on your video card than a 3D application like Rhino.
Rhino start up normally but I can’t modeling. The view (Right, Perspektive, …) doesn’t work I can’t put there anything. Only they are freeze. Actualization are current.
I tried that safe mode, that is work normal. What is the difference between normal and safe mode?
Updating the driver is always the first try. And normally results in the best outcome.
But, you can also disable opengl, which disables some of the display effects, like safe mode.
Go to Options->Rhino Options->Advanced…
Scroll down until you see “Rhino.Options.OpenGL.xxxxx” entries. Look for the entry “Rhino.Options.OpenGL.UseHardwareDriver" . Set that to false
