I have installed Rhino 6 (full version with license key) on a HP Z620 Workstation with 24Gb RAM and a Quadro K2000 graphics card. Then the program won’t start at all when clicking on the Rhino icon. The process just dies and nothing happens. I have tried the Safe mode and still the same. I have tried disabled graphic card acceleration and still nothing. I have even tried to install it on another workstation with the same specs and still the same issue.
Any ides what the issue could be? I’m thinking it could have something to do with the WIndows Update? Our environment is a high security environment that is not connected to the Internet and the Windows Updates are not installed that frequently.
My guess is that you’re running on a computer that doesn’t have the root certificates that are required for Rhino to check its own digital signatures. We’ve fixed this in SR9, which is currently in release candidate. I’ll send you a private link to that download for you to test.
Okay, thanks.
It’s probably a different issue with a similar symptom.
Does Rhino start in Safe Mode?
If you use the Windows’ Cortana/Seach tool, you should find a shortcut for starting Rhino V6 is “Safe Mode”.
Safe mode is a troubleshooting tool that blocks initializing OpenGL display and plug-in loading. Either of these can potentially block Rhino from starting.
That may be the underlying problem.
Local Admin Rights are required for Installing and then adding a license to Rhino.
If the IT guy didn’t start Rhino and add the license after installing it, then it can’t run because the Admin rights setup isn’t complete.
