Rhino Decal V6 Match
Hi everyone,
I was wondering if there is a way to match a decal s position on it s mirrored side like I would do with image maps using the match option ?
Thanks
Alex
turn the mapping widget on for the first decal, tehn make a 2nd decal and snap your decal to the corners of the widget. set one to project forward, one to project backwards. if they are the same size, this works nicely-
If your surfaces on either side are the same, just mirror the surface with the decal and then with the gumball set to “align with object” you can flip the decal so it’s the correct way.
