Two Questions Decals
  1. Is there a way to project decal trhough object so that it is shown on front and back?
  1. How can I import or send the decals to Keyshot as they are missing by default. Is there a simple bake option or a even simpler way to achieve this?
Thank you
there is a setting for projection on your decal for both directions-
BUT… since it project both directions, any text on the backside will be backwards…
the fix is to project the decal twice using forward and position it so it looks good on both sides with the decal widget.
as for your 2nd question, I do not believe that keyshot support rhino decals. I seem to remember you need to use keyshots decal feature
Thanks @theoutside for clarifying this. Makes total sense.
