nsgma
June 9, 2024, 2:58am
1
When you use “Mirror Alternate Tiles” in a Decal Texture things do not work as expected.
In Rhino 7 the texture does not mirror in both Rendered and Raytraced Modes.
Here is the rendered view with 5×5 without mirror
Here is rendered viewport with Mirror (no change)
Here is raytraced with mirror
In Rhino 8 is worse. besides starting acting up while I was doing these tests and eventually just shuting down, here is what the same looks:
here is rendered viewport without mirror and with the 5×5 tile. It changes the scale
when you mirror it mirrors but in groups of 5×5, i.e. every 5 lines it does not mirror.
In Raytraced the scale is not change but the texture is not mirrored.
Again Rhino 8 is slightly worse and slightly more unexpected than Rhino 7.
N
nsgma
June 19, 2024, 12:06pm
2
@wim
Any news here? were you able to replicate?
N
wim
(Wim Dekeyser)
June 19, 2024, 12:14pm
3
Hi Nuno -
I’m afraid someone that understands rendering in Rhino will have to take a look at this.
@nathanletwory , I see “Raytraced” is mentioned.
nathanletwory
(Nathan 'jesterKing' Letwory)
June 19, 2024, 2:06pm
4
Decal alternate tiles should work in 8.9 in Raytraced.
nathanletwory
June 19, 2024, 2:16pm
5
Looks like it is broken in Rendered mode at least on Mac, and according report also on Windows (didn’t check)
nsgma
June 19, 2024, 3:31pm
6
Hi Nathan,
Can you post you test model?
Thanks, N
nathanletwory
June 19, 2024, 4:28pm
7
I had already closed this file right after I had posted the screenshot, but here is a new one:
decal_with_alternatetiles.3dm (4.1 MB)
nsgma
June 23, 2024, 3:56pm
8
Hi @nathanletwory
Here’s what I see when I open your file.
I just noticed there is a new build available.
N
edit
After update the raytracing mirrors but the rendered view still looks off.
nsgma
June 23, 2024, 4:03pm
9
I am guessing this is one of those that will not be fixed on Rhino 7, right?
N
