Rhino crash while in Vray
I am experiencing crashes in both R6 and R7 that appear to be Vray 5.10.01 related, but I am not sure. In both instances Rhino does not create a crash log.
Crashes mainly happen while making adjustments within the Vray Asset Manager, during an interactive RTX render, though I did have a crash at startup in R7 when Rhino was loading the Vray plugin for the first time after installing v5.10.01.
Is there a way to determine if in fact this is Vray related?
SysInfo is attached…oddly the reports generated in both R6 and R7 indicate that there is no monitor attached to the second GPU when in fact there is.
thx
d
SysInfo_DS_210301.txt (3.1 KB)
Hello - hopefully you’ve been in touch with Vray support about this?
Under way…I generally find this forum to be significantly more helpful, so I stop by here first. Any thoughts as to why Rhino is not generating crash logs?
d
Ok - since we do not have VRay here, there is not a lot we can check.
I’m having similar issues, computer is freezing after pressing start production render button.
But it’s random, of course. Fine for 2-3 weeks, then a freeze or 2 in a row.
Press computer restart button, fine for a while.
Seems to have started in the time I switched to R7 & V5 from Sketchup (I don’t use Sketchup anymore on a daily basis so I don’t know if there are issues there as well).
Glenn
8700K Z370, (2) Samsung 850 Pro (smart data is healthy)
Vray 5.10.01
Rhino 7 SR3 2021-2-22 (Rhino 7, 7.3.21053.23031, Git hash:master @ f8a40388712d9cf7edc68910e0415427bdefc64a)
License type: Commercial, build 2021-02-22
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 2-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.72
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-23-2021
Driver Version: 27.21.14.6172
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.3.21053.23031
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
