When submitting crash reports, assume you are the only person having the problem and please carefully describe how we can reproduce the crash. If we cannot reproduce the problem, we won’t be able to fix it.
Hi, unfortunately I have the same problem, rhino crashes randomly, especially when I scale an object, additionally I started a render in Toucan now which should take me 5 mins, but rhino is showing me that it will take 4 hours, and it seems to be true!!!
If you are having a problem with OS X Mavericks, be sure to read this. We are not seeing problems here, so we need you to describe exactly how to reproduce the problem. So far, we cannot reproduce any of the problems that are very briefly described in this thread. We need more information. Also be sure to post your OpenGL settings so we can see what kind of computer you have.
Hi All. I have been experiencing crashes when I try to" save as". All I have to do is click save as and then click the drop down arrow to select the file type and the program and windows immediately crash. OSX Mavericks seems to still run fine, but if I want to get back into windows I have to shut down and restart. I am running Parrallells’ and maybe that is the issue, although I did not seem to have problems before Mavericks with this. (But did not do a lot of save as either.) I just wanted to see if it was a known bug before I uninstall everything.
I cannot tell for sure, but it sounds like you are describing a problem with Rhino for Windows and not Rhino for Mac, even though you posted this in a Rhino for Mac thread. Could you please post a screen shot of your Rhinoceros > About Rhinoceros window?
If you are running Rhino for Windows, you should know that running Rhino for Windows inside Parallels is not a supported configuration because of, among other things, numerous display issues.
Ah yes I did post this in the wrong place, I forget there is a MAC version. I am running windows on a MAC. I think my issue was Parrellels what I did was remove that and reinstall using Boot camp. That seems to have fixed the problem. I’ll just use boot camp from now on. It’s not as convenient to jump in and out of it now especially if I am using it with adobe products, but it’ll have to do.
