Rhino Closing While Trying To Open Files
So I am having trouble with Rhino closing 1 to 3 times when I am trying to load or switch files. I thought that the problem had something to do with the Plugin that I recently installed.
But after figuring out how to remove it, it continued having the same problem.
The only thing that I can think of at the moment that I changed other than adding that plugin was that I recently upgraded to Windows11. Could that Have something to do with it?
Here’s a few screenshots.
Opening File
Working on loading The file
Rhino closed
Trying Again on the same file
Loading
Successfully loads
Something to note also is that when I try to open a file from this stage to, I have the same problem.
I am using Rhino7 Educational with Windows11
I do have enough processing power as far as I know.
Does anyone know what is going on here?
Hi Ryan -
That could certainly have something to do with things, yes.
In the Windows Control Panel, please find Rhino 7 and pick the Repair option. Does that help anything?
Can you post your SystemInfo? This is similar to the recent AMD driver issues (turn off GPU Tessellation)
Not sure quite what you are referring to but here are some screenshots I took that might answer your question.
Something to note. CPU is unchecked on the other page in the below screenshot.
When I started Rhino Normally, opening a file from the Recent files list that comes up during the startup.
Running the TaskManager next to it.
It closed right after I took this screenshot.
My bad, please type SystemInfo into the Rhino command line and post the results here.
Okay, here it is
Rhino 7 SR24 2022-11-4 (Rhino 7, 7.24.22308.15001, Git hash:master @ cb2ad12922ceb989b185972675bb705a00abb97d)
License type: Educational, build 2022-11-04
License details: Stand-Alone
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) Iris(R) Plus Graphics (Intel) Memory: 1GB, Driver date: 9-5-2020 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce MX250 (NVidia) Memory: 4GB, Driver date: 5-5-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.78
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-5-2022
Driver Version: 30.0.15.1278
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Scan&Solve Pro for Rhino 6 & 7\SnSPro_Rhino_6+7.rhp “Scan&Solve Pro for Rhino” 1.0.0.0
C:\Users\Tracy\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Users\Tracy\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Karamba3D\2.2.0.171\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.24.22308.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.24.22308.15001
Hi Ryan -
When you launch Rhino without opening a specific file, does it then always start successfully?
Yes it does as far as I know.
Thanks, that means it’s file-specific.
When you launch Rhino, create a simple box in a factory-default template and save that file to your desktop, does Rhino have problems opening that file again later?
That worked well!
Thanks.
What happens when you disable the Lumion plug-in, restart Rhino, and then try to open one of your other models?
It still closed. First thing on the command line was Blocking Lumion Plugin. Not quite the exact words.
Here is another screenshot before it closed.
Ryan, Can you ensure that your using the Nvidia card per these instructions? Thanks.
Looks like it
Screenshot 2022-12-05 110811
Screenshot 2022-12-05 110833
Hi Ryan -
Can you post or upload (Rhino - Upload to Support) a file that makes Rhino close?
Here is a file. I wasn’t sure where to find your email so I’ll just post it here.
It didn’t seem to matter what file I opened. :confused:
12 by 16’ cabin with 8’ addition and loft.3dm (19.9 MB)
I have since a few months the same “problem” but not always and only the first time I start Rhino. I am using V6
My Sys info
Rhino 6 SR32 2020-12-5 (Rhino 6, 6.32.20340.21001, Git hash:master @ f0da95af49009959d0100568acb11aea288bcea0)
License type: Educational, build 2020-12-05
Windows 10.0.0 SR0.0 or greater (Physical RAM: 24Gb)
Machine name: FRITS-LAPTOP-HP
Computer platform: LAPTOP - Plugged in [96% battery remaining]
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 10-17-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 960M (NVidia) Memory: 2GB, Driver date: 9-23-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.19
> Integrated acclerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 9-23-2021
Driver Version: 30.0.14.7219
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.32.20340.21001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.32.20340.21001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.32.20340.21001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.32.20340.21001
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
Mine seems quite random, like not just at startup. Sometimes it works sometimes it doesn’t. Even between switching files it will do it. So confusing :confused: :man_shrugging:
Is that what you were looking for?
