Rhino BETA Feature: Patch re-implemented
Seems like the perfect time to implement my recent proposal to limit the amount of multi-knots per distance set by the user (like minimum distance of 0,5 mm or 1 mm).
@Rhino_Bulgaria Playing with version 4, it seems to be the best one to me. Take a look at it. There’s still room to push it further, but for patch testing I’m satisfied for now.
Complex shape test_bravi 3.3dm (6.8 MB)
Are you using “EdgeContinuity” to show the normal angle deviation? Or are you using Line with option set to normal form surface? I like how it illustrates the deviation for the point normal at those edges. Could be worth incorporating into edge continuity for angle tolerance.
No, that is just lines I drew by hand with_Line _Normal on both surfaces at their common corner. Then measure with_Angle _TwoObjects and put the result in a _Dot.
RH-89762 is fixed in Rhino WIP
History doesn’t work anymore.
I tried twice:
Sysinfo
Rhino 9 SR0 2026-1-13 (Rhino WIP, 9.0.26013.12305, Git hash:master @ 8c202752270c241e0a0b2e7326d1f869fc570aa1)
License type: Commercial, Build 2026-01-13
License details: Cloud Zoo
Expires on: 2026-02-27
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 9.0.1
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 12-2-2025 (M-D-Y). DirectX(11)
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26013.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26013.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26013.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRender.rhp “Vorgänger Rhino-Renderer”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26013.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26013.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26013.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.26013.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Thanks for reporting that, I made quite a few updates to the Patch command in the latest WIP and it looks like this got broken. I’ve created a ticket and this will get fixed before the next version.
I need to fix this, but in the mean time you can still get history to work if you ensure that history recording is enabled when you click OK. As you can see in your screen recording, history turns off once you started the command, and is off when you click OK. As said, this needs to be fixed, but I hope this helps in the meantime.
I’m using the Patch command in the part of the video shown. If you notice, during the command startup the selection and movement are a bit jerky and slow. I’m sharing the file — does this happen to you as well?
elmo medioevale.igs (535.9 KB)
I see this here with other geometry as well.
It becomes more responsive again when Rhino is fresh started (not meant to be a solution).
I never experienced the lazy reaction before last update.
I experienced the same issue: I restarted Rhino and it seems to be smooth again.
@Brv you are not using the latest update (I see the “Trim Ends” toggle, which was removed in the latest version) so the problem is not with Patch I think.
I’ve just updated Rhino and I see there’s now a new command called MultiBlend.
How exactly does it work, and what are some practical use cases?
Yes, this was introduced in the latest version for Patch; multi-blends were introduced recently for fillet and blend corners (see this topic).
Why is it not working in your video? Please see the error message in the command history window: it is not possible to mix continuities with multi-blend.
What is possible, is going from this:
Trimmed single surface patch
to this with multi-blend:
Multi-blend - multiple untrimmed surfaces filling the hole
The Patch command has stopped working correctly since the last Rhino 9 update. I am attaching a screenshot and the 3dm, file for reference.
Patch - Problem.3dm (107.9 KB)
That’s because PREVIEW is off.
I’d like to see Preview = True by default.
There have been numerous requests to have it off by default, because it can start a lengthy calculation that cannot be immediately canceled. The old Patch command (still usable by typing PatchOld - it does not autocomplete) does the same.
True!
PatchOld has a button for the preview, which is easy to find.
Patch has it as an option in the middle of the dialog.
No wonder Silvio and me didn’t see it immediately.
To have the same clear functionality as in PatchOld a preview button near OK/Cancel would be fine.
Or let the user decide:
If Preview is checked, then let Patch remember the setting.
Not revert to off every time.
Problem solved! :smiley:
@menno
I’m sure I was once (last summer?) able to get the left surface.
Today with (9.0.26013.12305, 2026-01-13) I only get a sick surface no matter what I try.
And it doesn’t trim. (EDIT: distance tol. 0.001 makes it trim)
Can you please show a screenshot of your dialog settings?
So that I can see my mistake and learn from.
