What happens if you extract 4 isocurves from the input fillets (blends) and connect them with 2 blend curves to give a better definition to the patch surface?
The command has been undergoing continuous changes and modifications. As we speak I’m working on it again. This is why the current results are sometimes different than in the files with examples. In general, I expect results to be better, but here that may not be the case for the same input.
I’ve taken @Rhino_Bulgaria suggestion and changed the internal curves a bit to make a slightly better behaved patch. You can double-click the patch to find the settings, but I haven’t changed anything so they’re default.
fillsrf-example-3_updated_MDvR.3dm (1.2 MB)
Having these new internal guide curves also allows for a multi-step approach. I’ve slightly tweaked the trim edge between the two fillets to make it continuous (*). This then gives you the option to make 3 patches, first the smaller two with G0 continuity on the internal curve, then everything G2 for the larger patch.
This results in 3 untrimmed patches.
fillsrf-example-3_untrimmed_MDvR.3dm (1.2 MB)
(*) because the edge is continuous, the large patch can merge the edges into one side of the untrimmed surface. If the edges are not at least G1 continuous, the edges are not merged and you won’t get the Untrimmed option.
Using 2 blend curves (starting from the side edges of the fillets) is the typical approach to fill such holes with 3 clean single-span NURBS surfaces.
Gijs, perhaps you could show how this one could work?
I don’t get something similar… not nice.
@Charles, I created that when we still had an option that was very finicky to use and was left out of the UI. So I won’t be able to recreate that example exactly anymore. Let me look into it again to see what the approach would be with the current state of Patch.
@Charles if you trim the two ‘fillets’ so that their edges become tangent, Multiblend creates a nice single surface. It’s not perfect in terms of G0 matching but the shape is pretty decent:
Patch_Multiblend.3dm (2.6 MB)
A great feature!
- I can imagine this is overlooked, because this is nowhere else in Rhino.
I have no fantasy how, but it would be nice to have a hint for that, not only the help. - The Edit mode is gone when the result object is copied or transformed.
Is it intentional?
About the constraint test results
In German UI it is Sch, G0, G1, G2.
Sch is the English Int, like in Osnaps.
From the help:
These labels use different colors to indicate whether the resulting surface meets the requested tolerances of Int (internal), G0 (Position), G1 (Tangency), and G2 (Curvature).
Can it be that the 1st result is not about internal points?
From what I see when playing around it shows if the result can be trimmed or not.
Confused.
The difference between Int and G0 is that G0 will participate in the attempt to trim the result, while the Int curves will not. Both will constrain the result to the curve position-wise.
If you think that the German translation is not correct, let me know (preferably with a suggestion). If Sch translates as “Intersection” that is probably needed, as it is meant to be a translation of Internal.
In Italian, “Int” is understandable: intern corresponds to interno in Italian.
In Romance languages in general, the meaning is equally clear, so “Int” is a comprehensible and consistent abbreviation at an international level.
Italian: interno
Spanish: interno
Portuguese: interno
French: interne
Catalan: intern
Romanian: intern
[Sch]nittmenge (“Intersection“)
[Int]ersektion (“Intersection“)
As a German, I would prefer Int too.
“Schnittmenge” - “Множество”, “Общ сбор” or “Площ на сечение” (Bulgarian), "Total amount, “Cumulative area” or “Intersection area” (English)
“Schnittfläche” or “Schnittoberfläche” - “Пресечна повърхност” or “Площ на сечение” (Bulgarian), “Intersection area” (English)
“Schnittlinie” - “Пресечна линия” (Bulgarian), “Line intersection” (English)
“Schnittpunkt” - “Пресечна точка” (Bulgarian), “Point intersection” (English) (a point intersection between two objects, typically lines)
Bulgarian:
Вътрешен (shortened as “Вътр.”), translates as “interior”.
Пресечен (shortened as “Прес.”), translates as “intersection”.
P.S. To “McNeel”. Contact me when it’s time for the Bulgarian version of Rhino to be released. I have a strong knowledge in Bulgarian language, including the technical terms.
Especially because in this case it’s about Internal and not Intersection.
In my opinion, it can be interpreted both ways:
- A surface built through a curve or point intersection.
- An internal curve or point used to build a surface.
Intersections are typically the output, while internal/interior objects are the input geometry.
